09-02-2014, 04:08 PM   #1
Unregistered User
Guest
The K-3 and Back Button Focusing
So I have my K-3 set to AF-C with SEL 2 and the focusing to AF2, i.e only focus when pushing the AF-button.
When using this way of focusing I find that the focus is not dead on when shooting an object that is not moving, for instance a landscape.
If I set it to AF-S/SPOT/AF2 I get a good lock on the focus but when trying to get the same result with the AF-C/SEL2/AF2-combo I am out of luck most of the times.
So; How are your experiences with the K-3 and Back Button Focusing? If you get it right; What am I doing wrong?
Been testing it for quite some time now...
09-02-2014, 04:47 PM   #2
Well, someone in this Forum - sorry I cannot remember whom to credit - had these suggestions for the following settings in the Custom Settings menu:
C.16 (First Frame Action in AF.C) = 3 (Focus Priority)
C.17 Action in AF.C Continuous Shooting = 1 (Focus Priority)
C.18 Hold AF Status = 3 (Medium)
I have adopted those, and whether I shoot Single Frame or Continous, this has worked fine for me since. However, I do change the focus point setting from situation to situation. According to the manual SEL 2-4 are intended for moving objects / objects that might move away from the focus point, but that shouldn't really matter?
09-03-2014, 04:14 AM   #3
Unregistered User
Guest
QuoteOriginally posted by Stone G. Quote
C.16 and 17 is the same for me but C.18 is put to OFF.
I will try the Hold AF but that will counteract the speed of the AF when following moving targets...
09-03-2014, 07:16 AM   #4
Does it find focus then adjust away from it? It may be lens dependent. I have two DA300's (long story) one focuses reliably, the other one does what I describe. Both with the 1.4TC. My 35mm macro did the same until I did the lens af adjustment.
09-03-2014, 09:11 AM   #5
Unregistered User
Guest
QuoteOriginally posted by derekkite Quote
The thing is if I use AF-S it will lock on and stay there and focus is sharp where I intended. With the AF-C it locks on but it is like if I have a little bit of front or back focus. I let go of the AF-button as soon as the camera beeps for AF-lock. I do not think it is moving away like you describe but I will have to test again.
Does you lens/lenses move away, as you describe it, when in AF-S?
My eyesight is not as good as it used to be so I depend on the AF when things are moving.
Would love for this to work as intended so that I no more need to change the AF-modes all the time.
09-03-2014, 09:22 AM   #6
Wired's Avatar
QuoteOriginally posted by Tjompen1968 Quote
When you let go of the AF on button do you move the camera? Even slightly? This can simulate the back focus.
I use AF.C with the AFON button and disconnected the half press shutter feature. I have not had a back/front focus issue.
https://www.pentaxforums.com/forums/38-photographic-technique/236970-perfect-...everytime.html
09-03-2014, 10:23 AM   #7
Ah, Found it! This post and the entire thread may give you some ansers and ideas:
https://www.pentaxforums.com/forums/172-pentax-k-3/251413-post-your-k3-af-set...ml#post2695922
09-03-2014, 11:19 AM   #8
Unregistered User
Guest
So I have tested this and that during the evening and, as usual in these cases, there are some user related issues. I have fine tuned my technique and I think I have gotten rid of the problem I had before. I still have the C.18 set to OFF.
I guess I needed the support from the forum to get my act together.
/Thanks all!
button, dslr, focus, k-3, k3, pentax k-3
Back Button Focusing? GDRoth Pentax K-5 & K-5 II 11 03-09-2021 05:50 PM
K-50 back button focus nna_misc Troubleshooting and Beginner Help 5 08-22-2014 01:15 AM
Replacing the focusing screen of K-3 TaiChiTom Pentax K-3 & K-3 II 60 04-12-2014 11:52 AM
K-7 back-focusing, and lens issues BigMackCam Pentax SLR Lens Discussion 13 03-24-2010 05:26 PM
K10D - ability for back button focusing? Neisey Pentax DSLR Discussion 8 08-19-2009 07:06 AM
All times are GMT -7. The time now is 06:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
