12-20-2014, 12:39 PM   #1
Fire a K3 with Pocket Wizard
Hi all, I have a friend who uses a Canon 5D and a Pocket Wizard with a particular lead and can use this setup to trip the shutter from a distance with a second Pocket Wizard. Do you know if this is possible with a Pentax K-3? If so what lead would I need to get?
Thanks a lot for any help.
Phil
12-20-2014, 12:52 PM   #2
jatrax's Avatar
It can be done with Cactus v5 so no reason pocket wizard would not work if it provides that function.
Plug end needed for the Cactus is the same as the one for wired remote.
12-20-2014, 01:07 PM   #3
Marvelous! I'll see if I can find it. Thanks!
12-20-2014, 01:27 PM   #4
Cactus v6 will also do remote shutter.
In-numerable $10 eBay wireless remote shutter releases for Canon will also work fine on Pentax since the same Canon mini-plug usually fits Pentax bodies.
12-20-2014, 01:47 PM   #5
It's the lower-end Canon DSLRs that use the same cable as Pentax; Higher-end Canons use an incompatible cable.
12-20-2014, 02:49 PM   #6
QuoteOriginally posted by DSims Quote
Useful to know. I was basing my observation on a no-name eBay wireless remote I bought for Canon working fine on my Pentaxes. Wasn't aware Canon had a variety of different plugs.
12-21-2014, 10:41 AM   #7
Otis Memorial Pentaxian
The compatible cable end looks like this:
12-23-2014, 05:49 AM   #8
Trudger1272's Avatar
I've used the school's Pocket Wizard Plus II on my K-3 and never needed a lead of any kind, but cables come with new PWs.
12-24-2014, 07:36 AM   #9
QuoteOriginally posted by Trudger1272 Quote
The image there seems to show a camera set up to fire a flash. I need to trigger the camera using the remote button on a second PW.
Thanks all, I will get the lead!
dslr, fire, k-3, k3, pentax k-3, pocket, pocket wizard, trip, wizard
K-3 and Pocket Wizard Trudger1272 Pentax K-3 & K-3 II 16 11-20-2014 06:16 PM
Pocket Wizard only fires ever 20 secs colinmiller18 Flashes, Lighting, and Studio 2 07-26-2013 11:48 PM
what alternative to pocket wizard? adwb Flashes, Lighting, and Studio 22 06-05-2013 03:59 AM
K-01 and Pocket Wizard PlusX radio wireless flash jon404 Pentax K-01 2 04-29-2013 05:55 PM
wireless with or without Pocket Wizard WMBP Pentax Camera and Field Accessories 29 02-02-2009 01:00 PM
All times are GMT -7. The time now is 03:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
