01-26-2015, 01:37 AM   #1
Video records focuspeaking
This is a straight screenshot of a video. It was taken at 720p (24fps) and looks like the focus peaking lines have still persisted. (I have it enabled)
Has it happened to anyone else or it's just a random bug?
Secondly, my shutter button gets stuck in between. Any way to lubricate it without disassembling?
01-26-2015, 02:24 AM - 1 Like   #2
Unregistered User
Guest
Check this thread... https://www.pentaxforums.com/forums/172-pentax-k-3/250619-focus-peaking-during-video.html
01-26-2015, 10:33 AM   #3
Thanks, I should try the search option first next time.
Besides, is anyone here having issues with their shutter button getting stuck during half press? Or it's just a irrelevant thing? I use the af button for focusing, but when I get ready to take the photo by depressing the shutter button, it gets stuck in that position once in a while.
01-26-2015, 10:59 AM   #4
Unregistered User
Guest
QuoteOriginally posted by akshay869 Quote
You could try to rinse it with lukewarm water from the tap and gently soak it while turning camera on/off and pressing the button for a while to get rid off possible gue that is stuck or have it replaced while under warranty...
01-27-2015, 03:16 AM   #5
QuoteOriginally posted by Tjompen1968 Quote
I'll try the lukewarm water method. Should I be worried about any ingression due to the water flowing at high speed?
I also have a small lubrication oil bottle that I got with my Braun trimmer, will try that as well.
01-27-2015, 06:02 AM   #6
Unregistered User
Guest
High pressure water is NOT recommended.
Using chemicals of any kind is NOT recommended.
Use ONLY water as I wrote earlier.
01-27-2015, 06:58 AM   #7
Thank you! I had to clarify the details.
01-27-2015, 12:11 PM   #8
Otis Memorial Pentaxian
Love the cool video effects!
OTOH, if you are having the problems you noted and your camera is still under warranty, I would suggest getting it fixed.
01-28-2015, 08:37 AM   #9
I had the sticky shutter button too. One night while doing the dishes, I just soaked my finger in the dishwater (BEFORE washing the dishes :P) and then played with the shutter button for a little while. The solution somehow diluted the sticky matter and all is normal now.
I've cleaned rubber parts for engines and other mechanical objects countless number of times, never had a problem. However recommanding a warranty fix is probably the best course of action.
01-28-2015, 09:45 AM   #10
QuoteOriginally posted by mamethot Quote
I don't live anywhere near US, (I had asked my cousin to get it for me on her visit here) so I don't want to part with it when I'm madly loving this damn fine camera! This is my first dslr and it really helps me capture photos the way I want it to.
I'll stick to trying non risky methods.
01-28-2015, 11:05 AM   #11
I went ahead with this solution assuming that the weather sealing would cover for this. However getting a warranty repair is easier than for you it seems.
01-28-2015, 02:55 PM   #12
Unregistered User
Guest
Dish water is ok in my book to use for cleaning the K-3.
dslr, k-3, k3, pentax k-3, video, video records
Shooting video with Pentax cameras. Tips, video looks, camera options, etc. JohnnyXD Video Recording and Processing 50 12-09-2014 09:53 PM
Hold Camera Vertical, records in Landscape - is this possible? redblur Troubleshooting and Beginner Help 15 08-21-2014 02:54 PM
I chose the largest recorded pixel but it still records small. LeeScree Troubleshooting and Beginner Help 8 06-16-2013 02:42 AM
$100 for President Obama's birth records jeffkrol General Talk 6 02-01-2011 09:55 AM
K-x - data speed records on SD card trdi Pentax DSLR Discussion 15 04-07-2010 10:47 PM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
