Each experiment was done with both K3 and K3ii and in all instances the results were identical so there's no need to separate those two cameras. My methodology was simple, not exhaustive. I just wanted to get an idea of what cards to buy.
For those that don't want to wait the SanDisk SD Extreme Plus 80 MB/s 32GB card is the absolute fastest in my cameras.
This is good news because I won't have to waste money buying premium cards as this is a three generations old card.
Every card I tested was fairly close, which is surprising because their specs were very different.
My methodology was simple. I set the camera on high-speed continuous, single memory card slot, raw DWG, kept lens cap on so every image would be consistently black. I started the timer at the first exposure and I ran it until I filled the buffer plus that first slow shutter click after. I ended he timer when the orange light went off indicating that the buffer was empty.
Almost every card tested took 33 seconds and some change to empty the buffer except for the Extreme Plus 80MB/s which did it in 28 sec.
Cards tested included the latest San Disk Extreme Pro at 280 MB/s! I expected big things from that card and was quite disappointed. All of my San Disk cards from 45 to 95 to 280 all performed identically except for the 80, which gave me a whopping 15% write speed increase.
Also tested a Transcend 60 MB/s card. And my previous champion a Delkin Elite 95 MB/s card that was far and away the fastest thing for my K5s.
I have a Lexar 2000 X coming in the mail I will give an update.
I can't really explain the results nor am I trying to. This was done with cards I already have so they're almost all different sizes from 8 GB to 64GB. I have not had a chance to test same sizes of different speed cards and only a few same speeds of different size cards. I just did the test quickly because I was going to buy a bunch for this back to school tax free weekend. So ended up buying about a dozen of the 64 GB data cards.
Certainly have no problem when it comes to buying SanDisk for reliability and certainly the 80s are not slower than the other cards.
The 280s do read faster in my computer through usb 3 but not that much. Not even sure if my card reader is compatible.
I'm curious. Has is anybody else done real world K3 tests and what were the results?
