Originally posted by mcgregni The main requirement that I'm aware of regrading 2nd Curtain Sync, is that the Flash Mode needs to be P-TTL (ie it doesn't work with 'Auto' or Manual Flash Modes). This applies to the flashguns and also the built-in flashes .... however, of course recently we have gained Manual flash modes on some of the built-in flashes. It would be really interesting to know if the K3 built-in flash allows 2nd Curtain Sync in its manual modes ... ?
Well, for the last, and
manual power settings in 2nd curtain ( Pentax call it Rear Curtain ) I notice there is different style of power flash settings in menu.
It is from -2,0 to 1,0, and I believe this is for flash power, or maybe exposure on final picture.
There is no classic customizable power scale settings for built in flash unit, like in
manual power mode (
1/128 - 1/1 ) ,
in Rear curtain flash mode, there is just some kind of simplified -2.0 - 1.0
I didn't put on hot shoe and try any external flash,
I just wanted to try out how the built in flash works in these mode.
Quote:
I suppose the 1/90th limitation is not really a problem as most of these types of 2nd curtain effects would only be noticeable at longer exposure times .... ?
Something like that, because effect of 2nd curtain, is visible almost only in slower speeds, or maybe it will be visible, when you will be shooting something really fast.
Then there would be limitation for this scenario
