Originally posted by EarlVonTapia I've taken similar shots, though not as nice (I use it mainly to take photos for buying and selling online, so I never need to make it super fancy)
Here's my setup.
https://instagram.com/p/i-JU37lX8P/
Here's the result
https://instagram.com/p/i9uDHnlX5U/
$10 of foam core at Walmart
any random manual flash. They can even be triggered via. the onboard flash, so you don't even need to purchase a trigger.
A yongnuo will set you back around $75.
Under $100 and you'll be good to go.
EDIT: I should add, with a little bit of practice, refinement, and post processing, you should be able to get similar results to your example photos.
That is very impressive setup and shot. Right now, I'm helping a small company to set up the right equipment set, but I'll definitely try it for myself at home. About flashes, I need to buy 2 flashes, right? One attached to shoe mount and another to light the back panel, something like that? I've been using continuous lights only, so please bear with me
---------- Post added 03-26-15 at 02:48 PM ----------
Originally posted by Na Horuk Yeah, these days you can just buy a little tent with lights and all, no need to piece it together yourself.
What you need are soft lights (diffused, reflected). If you use continuous lights, make sure they have a full spectrum (no missing wavelengths) and make sure their flickering will not interfere with the photos.
Or use flashes, umbrellas..
You would also need a background, which has to be a little farther away from the object (so shadows and stuff won't show up). Its a good idea to use the kind of background that seamlessly bends into the bottom base where you rest the product. And usually you want to use a separate light to equally light the background to pure white. Avoid patterns or something with uneven gloss, texture
Good idea to use a macro prime lens, like HD DA 35mm f2.8 macro or DFA 50mm f2.8 macro, but if you want to go cheap you can go with something as old as Pentax M 50mm f1.7 and it will be sharp enough. Macro lenses just give you that clinical, sharp look, and they let you take those closeups of fine detail.
Oh and get a tripod or some sort of base for your camera. Bonus points for remote trigger. Then simply use 2 sec timer, Av mode, ISO 100, f5.6 - f8 (or even bigger f-number for wider DoF. But if you go above f10 or so you will need extra sharpening. DoF should be wide enough to fit the whole object, but not any wider than necessary.)
A lot of these things you can do fairly cheap if you are clever and patient. Of course, if you want things done right, it will cost. This is why product photography is a business. Amazon even has a patent for "white background" product photos.
Thank you so much for your great advice! That is really helpful-Do you think M 50 1.7 would be a better candidate for products shots than DA 50 f1.8? Just wondering because I'm getting both this week:-)
---------- Post added 03-26-15 at 02:49 PM ----------
Originally posted by CarlJF This really look like it was taken with a macro box, similar to that of ErlVonTapia. You should get a look at this How-To, which has a slightly different design, the flash being outside the box shooting through a diffuser:
DIY 10$ Macro Photo Studio.
I googled ErlVonTapia but nothing came up. Could you let me know what ErlVonTapia is? --->>> WOoooops. Sorry, ErlVonTapia. I missed your user ID! LOL
