Godox sells an amazingly cheap manual ringflash (not LED). $100 region. I have a pair of their big flashes and they are brilliant. I can't say I have ever used the auto settings on my sigma 'ring' (actually dual) flash. I feel macro needs the photographer to take control of the settings. The Godox is setup for manual so there is never any messing around with menus. By the way the LED lights are almost useless other than fill light.
"Or should I just try to master my cheap Godox flash?"
Which flash are you talking about?
mastering ring flash manually is easy
1. whack on your lens and flash
2. set a manual aperture
3. Guess the power (usually between 1/4 and 1/16)
4. do a test shot
5. Modify the power
'Will I benefit in a great deal to have a ring flash instead of a normal flash?"
Ring flash is only useful if the subject is arms length or closer
If you have the big godox keep working away with it for normal
Again set you camera for manual of X. Set your aperture you want and make adjustments to the power on the flash. The big Godox is great for bouncing the light off surfaces. I use a small or large lightbox on the flash when using directly
