Just upgraded from Nikon D7000 to pentax K1. The main purpose is to do occasional astrophotography using the astrotracer. So, after getting the new K1, I tested the noise at different ISO settings: 1) different ISO, same exposure (increase shutter time); 2) same exposure time, different ISO, then use Adobe Camera to adjust the exposure to the same level (all exposure were adjusted to ISO 6400 equivalent). The following is my subjective results.
First, different ISO, same exposure.
The result shows there seems to be two critical points: ISO 800 and ISO 25600. The noise levels from ISO 100 to 800 are really close. After that, increasing ISO leads to increased noise (looks like linear). However, if ISO is more than 25600, there's a big increase in noise. When ISO is more than 51200, the noise and color become unacceptable. Following are the images (around 70% ~ 100% crop, didn't remember the exam numbers... Lens: Pentax FA 50mm, F1.7, shot at F4). Corresponding images were uploaded and sorted by ISO.
Secondly, if I shot at relatively low ISO (800 and higher) and then adjust to ISO 6400, the noise level seems to be a constant. The noise level is similar when shooting at ISO 12800 and then decrease to 6400. However, shooting at 25600 (decrease to 6400) results in some clipping (maybe artifacts from change in light conditions).
ISO: 100
ISO: 6400
ISO: 51200
Edit: images from imgur are not showing up. Trying to fix but failed, but images are accessible through the link.
It seems, setting ISO to 800 may yield best results given that it provides the best dynamic range. I'm still learning so the conclusion probably is not true. Let me know if anyone has some insights or suggestions.
Best,
Ming
Reason: Images not showing up
