08-25-2016, 12:36 PM   #1
Electronic Shutter
Does the K1 has some sort of electronic shutter?
Thanks
Jorge.
08-25-2016, 12:38 PM - 1 Like   #2
MJKoski's Avatar
It does in Pixel-Shift mode. Other than that, no. Kind of shame.
08-25-2016, 01:14 PM   #3
I'll be waiting to the implementation, maybe they can do it via firmware, if not I'll have to wait to the next iteration, I think is very important, at least first curtain, in order to unleash the full potential of the sensor IQ
08-25-2016, 01:22 PM   #4
RobA_Oz's Avatar
I presume there's a reason why it hasn't been implemented outside of pixel shift, but I've no idea what that might be. There are several situations in which it could be quite useful, including where vibration sources need to be minimised. The fact that it is used in pixel shift means a firmware implementation is possible. I'll leave it to the more knowledgeable to speculate on why we don't have it now.
08-25-2016, 01:42 PM   #5
MJKoski's Avatar
D810 using the same sensor has EFCS in Mirror Up -mode. But then one can guess if it is really the same sensor. As A7R1 from Sony does not have EFCS either ("same" 36MP chip). Standard A7 mk1 had one.
08-25-2016, 02:05 PM   #6
My guess would be that they'll add it in the next model. It's a nice feature to have, but not critical.
08-25-2016, 02:18 PM   #7
MJKoski's Avatar
Not that critical with large mass body but very critical in Sony's MILC offerings. D810 also makes good use of it when shutter speed is between 1/100 and 1 second when using longer lenses.
08-25-2016, 02:40 PM - 1 Like   #8
photoptimist's Avatar
An electronic curtain that maintains sensor IQ is hard to implement. With a physical shutter, the sensor sits in total darkness and the pixels can be kept at near zero charge so that they can more accurately measure very low levels of light. But if the physical shutter is kept open, the sensor is just one giant solar cell. The electronic shutter circuitry attempts to drain off that excess charge but it's never perfect.
An electronic shutter can work relatively well for Pixel-Shift mode because: 1) the time the sensor spends in the light before the next exposure is pretty short (under 1/4 second), and 2) the adjacent pixel location is probably of similar brightness to the first location so any slight smearing from imperfect draining of the charge isn't going to be as noticeable. It can also work well in the way Nikon uses it on the D810 as part of mirror-up mode, non-liveview shooting in which the sensor is only exposed to excess light for about 1/250 of second during which the camera is almost stationary.
08-25-2016, 09:07 PM   #9
Scobra's Avatar
Electronic shutters come into their own in timelapse photography, where a few long timelapse shoots can substantially erode your mechanical shutter lifespan. Mechanical shutters are said to have (slightly) less consistent exposure times too, adding to timelapse flicker. So yes, please Pentax, introduce electronic shutter if you can.
09-06-2016, 12:26 PM   #10
Otis Memorial Pentaxian
Well put...well put indeed
09-06-2016, 12:36 PM   #11
QuoteOriginally posted by MJKoski Quote
I have some familiarity with the D810 and knew that EFC is available in Mup mode, but was unaware it is used in other situations. Is that an undocumented feature?
09-06-2016, 06:50 PM   #12
clackers's Avatar
Yeah, there are plenty of P&S cameras without mechanical shutters, but we bought DSLRs for image quality and we need to know the design suits, without artefacts or lag:
Electronic VS mechanical shutter | JuzaPhoto
http://m43photo.blogspot.com.au/2012/12/gh3-electronic-shutter.html
09-06-2016, 10:42 PM   #13
Micro 4/3rds Photography: GH3 electronic shutter
Oh, my! That article on the GH3 electronic shutter is an eye opener. Thanks for the links.
09-07-2016, 06:20 AM   #14
MJKoski's Avatar
My bad, I meant that there is a benefit of using EFCS with D810 with such exposure times.
dslr, full frame, full-frame, k-1, k1, pentax k-1, shutter
Mechanical Shutter vs Electronic Shutter... ? watchingskyfallatm Photographic Technique 6 01-11-2018 07:23 AM
Mx-1 electronic shutter tootal2 Pentax Compact Cameras 4 12-31-2017 05:43 PM
K1 pixel shift and electronic shutter biz-engineer Pentax K-1 & K-1 II 9 06-01-2016 09:46 AM
K1 menu - electronic shutter 2351HD Pentax K-1 & K-1 II 6 05-05-2016 08:57 AM
Leaf shutter vs Electronic shutter? Ishpuini Pentax Q 8 11-14-2012 04:33 PM
All times are GMT -7. The time now is 01:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
