Originally posted by tunjij need a trigger that will send TTL info to the flash
Just to clarify, Pentax has stopped using TTL a little while ago (starting with *ISTd I believe). Now they use P-TTL. Still the same principle but it uses pre-pulse to calculate exposure and then re-flash for taking the shot. And P-TTL and cheap won't appear in the same sentence...
For wireless P-TTL trigger, you're out of luck. Pentax only support optical slaves and no one makes a true P-TTL radio trigger. There is a company called Aokatec (
Aokatec - Products) that jimmy-rigged a system to convert optical on camera flash to radio and then from radio to IR to fire off the flashes. It looks promising but I never heard of anyone using them. Check their website.
You can use your on camera flash set as "Controller in wireless mode", it shouldn't affect exposure (in most cases). But if you'r gonna use a softbox, optical may not work.
Or go the good old manual mode and get some $25 Ebay radio trigger and adjust your flash and exposure manually.
And for the box, Metz is using a fairly standard design, I can't see why it wouldn't fit. But I never used the combination.
