Originally posted by bdery Yes it does. I currently use the Sirui T-025X with its C10X ballhead. The ball is ok, but I miss the friction control, absence of sag and strength of the panning screw on my former Vanguard head (I still have that one but it's too large for the tripod). So I'm considering alternatives, and the Sirui K line of heads seems very interesting. Probably a K10X for me, since I want to keep it as small as possible.
What's your opinion on the K20X ?
One thing I'd ike to see is a head with two drop slots, like a discontinued Sunwayfoto I've seen before (not sure about the model).
I decided on the T-1205x over the 025x since I already had the K20x. I haven't compared the two sets of legs in person, but they seemed pretty comparable in paper, with the 1205 being a touch less compact (but still fitting in my bag) and a touch more sturdy. But they're quite similar, so it should be close to your experience.
You'll have to mess with it a bit to completely fold up the tripod. The head is slightly too large for this functionality, I suspect, and I really wish the knob for the ball head and the knob for the rotation were at a different angle from one another -- say 120 degrees instead of 90. And if the drop slot was 120 from those, it would be
perfect. But it's not, so it can be a bit of futzing around to get the tripod legs to close up completely.
The k10x may not have as much of a problem, but I wasn't sure if the 10x would be strong enough, where the 20x will handle anything Pentax can throw at it.
The only complaint I have with it, and I think this is really just a complaint with ball heads in general, is that it's a pain to change targets on the fly if they're not on the same plane (i.e., if you can't just pan). You either have to leave the ball head loose enough that it's no longer rock solid when you stop moving (i.e., it might sag if you let go), or tight enough that it takes enough effort that I'd worry about knocking the tripod over. It might be that hanging weights from the tripod will make this easier - I just got the 1205x a few weeks ago and haven't used them extensively yet, and my old legs didn't have a hook. But when it comes down to it, I suppose, this is what a gimbal head exists for. Which is why my next purchase pricey camera gear purchase will probably be one of those.
I haven't been able to compare it with any other nice ball heads, because the other ball heads I have had were junk (a compact one for a monopod, one that could barely hold a point & shoot, and the not completely terrible one that came with my old "slik sprint pro II" tripod. That one worked OK when I just had a D5100 and a couple of lighter weight lenses, but couldn't handle the K5's weight with any decent lenses.
