Originally posted by raider I see....so the red dot is almost like a super powerful focusing beam similar to the one on the camera...except it is able to go long distance?
I think you are picturing some kind of laser target you might see in a shoot-em-up movie on the chest of the bad guy, who then drops his weapon. There's no laser at all.
It is just a guide you use to aim the rifle or camera, like cross-hairs on a traditional rifle scope. The dot doesn't project outside the aiming device at all and it doesn't assist focusing. If the Red Dot Sight was attached to a rifle (for which it was designed) and properly sighted in you would have approximate aim to fire at your distant target, but there wouldn't be any dot ON THE TARGET ITSELF. It stays inside the device. Then you would use your accurate sighting device to actually fire. In much the same way, your Red Dot Sight will allow you to approximately AIM your camera, but composing and focusing remains purely a camera or manual function.
This device is most useful for a camera that only has an LCD and no viewfinder of any kind available to AIM the camera. It gives a much wider field of view than the telephoto lens, so you don't need to saw around 'looking' for your subject. Once approximately located you compose and focus with the LCD.
Go here to read and see.
