If you are new to this, these "angelic" waterfalls pictures are not an easy start. The technique is not that hard but properly understanding exposure is a must. However, if you're willing to learn, nothing prevents you from trying to figure it out as you go along. The trick for this effect is to expose your picture long enough for the water to begin to blur (5 seconds to a minute depending on flow). Aside from a camera there are two things which you will need; A decent tripod and a Neutral Density filter. I could go in more details but it does get a bit technical and if you do not master your camera and its settings yet, you'll just get lost.
For a beginner, the 18-55 is very acceptable, not great at anything but decent enough to create great photos. The 16-50 is better for sure but until you get the hangs of it, it will be wasted money IMO and once you figured out a few things, you may want to go with prime lenses instead of zooms. And as you go, you will see if you require a wider lens, a longer lens, a faster lens or whatever.
Read, try, fiddle around with your camera, read some more, try different things and work hard at understanding all everything works and to begin with, try to get properly exposed images, work on composition and on your technique, if you try to skip too many steps, you're gonna have a hard time.
This whole thing may seem technical at first and it may take a while to figure it out but once you'll get it, it'll be almost second nature to play with your settings to get what you want. But it does require some (little) commitment if you want to learn. As soon as you get the basics out of the way, you'll discover a whole new world of opportunities.
Someone posted a bunch of free photography e-books recently, some might help. I'll see if I can find the link.
Here is the link:
http://www.lightstalking.com/23-more-ebooks-for-photographers-that-are-completely-free
It was posted on the forums by someone else, but I can't remember who, so credits to Poster X and not me
Reason: Added link
