Originally posted by ttcgreg You mentioned a book, do you have the title???
Sorry to say, but it's German, so the title probably won't help you.
And there's certainly no big knowledge on my end. I've been using DSLRs for a few years but consider myself quite a newb. But learned so much once I started visiting this forum.
Is the 50mm the only lens you got for your camera or did it come with a kit lens, too?
/edit: oh, one very good advice I got from that book is to change the way autofocus works. Preset, and what most people know from their point and shoots, is that you focus when half pressing the shutter release. But you get a lot more control if you disable that and only use the AF button on the back of the camera instead (because otherwise you can't take a picture without it refocusing at half press).
Takes a bit getting used to, but not too bad.
You can find that in the camera menu page 4 "Button Customisation" - "AF Button" and set it to "Enable AF2".
I don't mean to overwhelm you by adding to what's new to you, though. I've been perfectly fine using the standard half-shutter-press for years.
