Noise reduction programs analyzes images, usually shot at higher ISO, and reduce the noise, improving the final image. I have been using Noise Ninja 3 with success to improve my images for years. At the time of my purchase of noise ninja, I had tried a number of noise reduction plugins, and liked noise ninja best. Over the years, these programs have been upgraded to higher versions, and I was curious how they stacked up to my Noise Ninja 3. Is it worth purchasing an upgrade? To answer these questions, I compared the current versions of a 4 noise reduction plugins, and compared them to my Noise Ninja 3. The five most current noise reduction plugins are that I compared: Neat Image 7.4, Topaz DeNoise 5, Photo Ninja 1.1.0, NoiseWare 5.02, and Define 2. The comparisons are meant as a guide, and of course everyone has their own preferences. I tried to get the best noise reduction in all of the samples as I could, and went back and forth many times between plugins to get each image as clean from noise as I could. These are my observations.
Descriptions:
Noise Ninja comes as a plug in and stand alone program. When initiating it, it starts with auto selecting regions to map the noise, that can also be done manually. I really liked this because I felt I had control over the optimum regions to select. Also there are a wealth of pretty logical controls to optimize the image.
Photo Ninja, is a raw editor like Bibble, Lightroom, etc. When calling it as a plugin, it loads the whole program the first time (patience!), and leaves it open after sending the image back to photoshop. The Noise Ninja 4, that is part of it, has dramatically simplified controls compared to version 3. However, images can be tweaked in other menus (such as exposure and sharpening)
Noiseware has a wealth of controls for advanced tweaking, but also has plenty of presets to simplify the use of the program. It does not allow the user to select regions, but instead allows the user to adjust the noise from the autoprofiler.
Neat Image has similarities to Noiseware in adjusting the autoprofiler, but gives the user more control over the mapping of a noise region. In addition to autotune, it also it has a couple of presets. Noise Ninja 3 actually let the user select many noise regions.
DeFine is a plugin that embeds itself along with the whole Nik Collection in a window, and is not yet compatible with Photoshop CC.... it wiped out my settings... One can manually select multiple regions and control the noise reduction separately using additional control points.
Ease of Use:
By far I found Topaz Denoise to be the easiest plugin to achieve satisfactory results, with relatively few sliders. Photo Ninja also is relatively easy for initial adjustments, however, being that it is a raw editor, you have to adjust the image in other menus or in photoshop for further improvements. Noiseware has a steeper learning curve because of all the different adjustments that are available. Neat Image also takes a little practice to get a feel for the program. Noise Ninja 3 has pretty decent default settings, and is pretty straight forward. Nik's Define was incredibly easy to use, even easier than Denoise.
Speed:
Noise Ninja 3 and Neat Image were fastest. Noiseware and Define were pretty fast also. Denoise and Photo Ninja were significantly slower. One thing I noticed is that Photo Ninja allows the user to make adjustments while it is calculating the preview, where Denoise needs to finish the preview calculation before allowing the user to make adjustments.
Samples:
Samples:
Here is a 100% crop of the original ISO 6400 image:
Noise Ninja 3:
Photo Ninja 1:
DeNoise 5:
Noiseware 5:
Neat Image 7:
DeFine 2
Notice the details in the hair and face of the lady, the overall softness of the image, the quality of the out of focus man with the hat, the artifacts in the top left orange and red sections on the wall, and the overall graininess.
