Originally posted by 35wailin Hi all, I am kinda new to post processing. That being said, I use Picasa right now to organize my shots and have played a bit with the settings in the past. I also have a paid copy of Photoshop Elements 11 that I bought for my daughter's high school computer class. Also have Silkypix that came with my K-50.
Pro/con for each? Is one better than the others?
All of them are going to have advantages and disadvantages, and everyone has their own personal preferences in terms of how they like to work on their images.
I've got the K-30, which is pretty much identical to the K-50 in most respects. Right off the bat, I'll say the following:
In my experience, when I nail my exposures, I have a hard time "bettering" the JPGs that come out of the camera with any of the RAW converters I've tried. If you can get your images "right"
in camera, then you may only need a simple program to do cropping/resizing and other basic adjustments ( something like FastStone, which is free and lightweight ).
But the camera can't read your mind, so if there's some special creative processing you want, you have to do that in post processing, and if you're going to do something radical, you'll probably
want to start with the RAW file and use a RAW converter.
I've tried the following:
ACR ( via Elements 9 )
Rawtherapee
Silkypix 3.0 ( bundled with the K30 )
DxO pro 8 ( recently installed via free license offer )
When I'm not dealing with tricky lighting, or trying to recover blown out highlights, I've found minor adjustments to the camera's JPGs give me better results than anything I've
been able to wring out of these RAW converters - and I've spent time working on the same photo with each converter in turn, with different settings, trying to see if I could get
something that was more 'pleasing'. The camera's JPG engine does a very good job of balancing noise reduction vs detail retention.
This will generate howls of protest, but from a pure usability perspective, Silkypix is actually the best of all those programs for my workflow, once you get familiar with it. The interface is a bit different from what
most people are used to, so I think many never take the time to familiarize themselves with it. A nice advantage is that it allows you to create your own presets ( what they call 'tastes" ) for
every subsection of the adjustments, as well as global presets. I find it is far easier on my computer's CPU than the other programs. Most of the functions you'll need are there.
Hands down, it is the fastest at updating the previewed image - in fact, you can scroll through a drop down menu and it will revise the preview as you hover over the various options,
allowing you to pick your preference without the need to apply/undo each one in turn. As far as the output goes, I've found that on average, I'd rank it second to DxO.
I haven't been able to get it to bring down the noise without messing up fine detail as well as DxO.
Rawtherapee is very complex - there are a LOT of options included, and it may simply be that I don't understand it enough to get the best results out of it. It does have some nice features,
but it suffers a bit in terms of usability. It's also the buggiest of the programs I tried. Certain basic functions related to configuring/saving/applying presents simply do not work correctly, which
makes me wonder if there are also less obvious bugs lurking down in the bowels of it that may account for deficiencies in image quality. I've never been happy with the noise reduction - it tends to obliterate fine detail. But like I said, there's
such a bewildering number of options and adjustments, it may simply be that I couldn't get it set up correctly. Oh, and it's a bit of a resource hog.
Elements includes a dumbed down version of ACR. I've never been super happy with the RAW conversion side of it - it gives you only a small number of options for adjustments in RAW
conversion ( yes, I know, I'm also complaining that Rawtherapee has too many ). Once the conversion is complete, Elements gives you the largest number of options for editing/adjusting your photo, including layers, etc. Elements is on the slow side if
you've got a lot of RAW images to go through.
I'm new to using DxO ( just got a free license for version 8 off their website ) and still figuring it out, but I like what I'm seeing so far. The fact that it will automajically correct vignetting, distortion, and chromatic aberration
for any camera/lens combo that they've profiled is great. It doesn't seem to support any of the 'normal' keyboard shortcuts I would expect it to ( eg. <cntrl>-s does not trigger save/export ). Strangely, it doesn't seem to
have a "highlight recovery/reconstruction" tool like all the other converters. It's extremely slow at updating the preview while you're making adjustments, which can make the adjustment process a bit tedious. If you can
get a basic set of adjustments saved as a profile, and apply that to multiple images, that speeds things up. DxO seems to do the best job of balancing all the various trade-offs in terms of image quality. I just wish the
usability was a bit better, but that may improve as I become more familiar with it. Perhaps some of these deficiencies have been addressed in the more recent versions of the program.
For browsing/comparing/culling images and performing simple adjustments to JPGs, nothing I've tried beats FastStone.
Though it suffers a bit on the usability side, I'm leaning towards DxO as my RAW converter of choice right now. If I could get as good results from it, I'd take Silkypix over DxO for its
usability.
If I need to stitch a panorama, or do something with layers, or other heavy duty editing, then I'd use Elements.
So as far as I'm concerned, you've already got two decent programs to work with ( Silkypix and Elements ). FastStone is a free/donation program that makes a great image browser, and you can configure it to
launch both Silkypix and Elements ( via 'Edit with' ). These programs all play well together on my machine. The 'Edit with' doesn't work quite as nicely with Rawtherapee and DxO.
