Hi there
Today I tried to visual calibrate my monitor contrast&gamma. I am totally confused by my monitors (Benq GL2460) internal settings. I know this is an "desktop monitor" so I do not expect any super accurate calibration result.
The problem is the setting: HDMI RGB PC-Range:
0-255
or
16-235 (factory default)
My understanding was that 16-235 is needed for reduced colour range of video playback (blueray,dvd,psp,xbox...). I believe it has also something to do with YUV or color compression.
And 0-255 should be the choice for image editing, but when I enable it the monitor is absolutely to bright in dark areas in images. Spots which should be black are quite grey. A black desktop background is also noticeable grey. Even if I turn brightness and contrast to zero in the monitor. I did not touch any gamma settings of the graphics card nor changed the monitors gamma (set to 3 of 1-5). And color setting is set to "sRGB"
Does anyone use 16-235 for image-editing? If I use that I get a good blackpoint.
