Originally posted by GeoJerry Can I then tell Lightroom that the photos are now on Drive B and all is well? Without manually doing it for each image or folder of images?
If you delete an image on the hard drive and Lightroom has it in its catalog, it won't be able to find it, and it will tell you that. It will also give you an option to find it yourself - so you can browse to a new folder, and find that missing image file. And there is a checkmark that tells LR to do look for other missing photos in this folder. So if you move or rename folders on hard disk, its not a big problem.
However, some data is stored within the dng file itself. So if you lose an image and then use an older dng file, it might look different. Especially if you use more than one PP software (LR, and Photoshop, and plugins). So you might lose some PP info if you delete dng files and then find older backups.
