Originally posted by Rnovo I use the AF button - above the LiveView (LV) on the K5IIs - as a standard now for a couple of years (See your manual on how to disable the half press AF). I only use the shutter button half press AF for sports photography or action shots where I don't have time to press the AF button in between shots, for the following reasons:
1- As soon as you press the shutter button the AF will activate on a spot you don't want it to... Use the AF button to focus and maintain the same focus irregardless of using the shutter - or use manual focus (the katzeye spilt screen will help for that). In your case it make total sense...
2- Using manual makes sense when you are shooting in a know environment (studio, gym, interiors, stable daylight...). Av will change your exposure every time and you end up with different exposures every time forcing you to increase your workload in PP...!!!
3- I use those 95% of time.
4- the K3 has an AF button right where it should be maybe - at your thumb - because it is a better way to focus 90% of the time...!
---------- Post added 12-21-14 at 22:38 ----------
On the K7 the "AF" button is in the middle of the selector button for your meter.
Ah got there!
Thanks so much everybody for your help.
A lot of people have told me that back button focusing really makes a difference for wildlife. I'm coming to the view that it can help get those special moments in portrait/ candid photography too.
---------- Post added 12-21-14 at 07:53 PM ----------
BTW: If you are in Australia, Peter Coulson is a fantastic teacher of photography skills as well as a leading fashion/ glamour photographer. If you do any kind of portrait shooting, keep a lookout for his workshops.
