Originally posted by r0ckstarr What does the conversion consist of? Is there a tutorial somewhere on how to do it, and what all is involved?
The conversion involves disassembly of the camera including desoldering parts, removal of the UV/IR/AA filter in front of the sensor, obtaining an IR cut off filter, cutting that filter to the exact size, installing the new filter, not electrocuting yourself on the flash capacitor, reassembly, adjusting the fine focus, and maintaining a clean environment.
Or
Sending your camera to a shop that does the conversion.
Or
Buying a converted camera from one of several retailers that maintain an inventory of converted cameras.
There are several sites online for each of the three options.
I chose the second option at a shop in San Diego, for a cost of about $250.
My regret is that I did not convert the top of the line model, instead I converted my old K10. An IR conversion is a relatively rare event for me (and most folks). I should have spent the few extra dollars for an IR camera that would last me for years and years, in contrast to my main "normal" DSLR which I upgrade every three years. I miss the extra megapixels for cropping and enlargement. DR and high ISO performance are sufficient for me from my K10 IR for my landscapes. If I were to do this again, I'd use a K3 II.
---------- Post added 10-13-15 at 10:59 PM ----------
Originally posted by fwwidall I have a 720nm converted*istDL2.
Unconverted *istDS. ISO 800, 1/8s, F8.
Fantastic images! What kind of filtration did you use on that last image?
