Originally posted by ruslanvremea I meant the item MEMORY in the menu that allow to save in the EXIF extra settings as: flash mode; drive mode; white balance and so on. I checked all this boxes.
No relation to EXIF. To make sure, I just tried unchecking both sensitivity (ISO) and Exposure Compensation and did an exposure with my K-3. Both settings were present in both the standard EXIF and in the makernotes sections of the metadata.
Originally posted by ruslanvremea It's not about software, in attached in first post picture, I tried to show how my EXPLORER read files properties of the photos taken by my K-3 and other Pentax body.
So they are....sorry for the confusion, my bad
As for your K-3 vs. your other Pentax body and Windows support for viewing EXIF as properties and presence of preview image, I have no explanation except that neither my Win 7 Pro nor my Win 10 Pro computers are able to read the EXIF from PEF or DNG from my K-3 or from the K10D that I had before*.
What I see for EXPLORER on my Win 10 computer is the same as what you are seeing on Win 8...No preview, no properties except file size, and no nothing except for file information.
My conclusion, based on your clarification, is that there is nothing wrong with your camera and probably nothing wrong with your computer except maybe an outdated set of supplemental DNG/PEF codecs. As noted above, you might want to try the free codecs from Adobe. The most recent version should support your K-3.
K-3 DNG properties in Win 10 Explorer (no additional codecs installed):
Thanks for the clarification and your patience.
* FWIW, the same has been true of my XP Pro computer. It is currently not bootable or I would check it too.
