Originally posted by junousia I'm not very familiar with portrait photography and I have read now quite many web instructions. Still I'm a little bit confused how to compost the subject. All instructions advise to focus to the eye (head and sholder portrais) and the height of the camera should also basically at the same level, and use Golden rule. Thats quite clear for me.
But after that if I take the photo then there is too much free space above the head. Do I tilt the camera a little bit (not good idea?) or do I lower the camera (maybe not) or do I edit the photo with photo editor afterward.
Which one is commonly use practise?
Br. Jukka
As you can see, you have already gotten four different replies to your question. I am going to throw my answer in the ring too.
First, I am going to take a guess and say you are using your center focus point. If not, I would highly advise that you do so. This way you have full control of what you will be focusing on.
When you focus on tour model, yes you focus on the eyes. This is what draws people into your photo. Now depending on how far away you are from the person you are taking a photo of. You might see a lot of room above the top of the head. Back in the day of film and even into today, you would normally drop the camera aiming point down a little so you don't end up with a lot of space above the head.
Keep in mind if you are going to recompose after getting focus, you will need to hold the back button or the shutter button half way to lock the focus while recomposing. If you don't lock your focus you will need to start over.
Also, if you don't feel like recomposing after locking your focus, you can always crop in post production.
Both are acceptable. I, myself try to recompose most of the time but sometimes I do need to crop.
