09-16-2014, 06:56 PM   #1
straight from camera
Lens: 50-200 Camera: pentax k-50 ISO: 200 Aperture: F5.6
Good day!
This picture is straight from my camera.
I would love to hear your thoughts on it, as I'm still learning!
I don't remember what my shutter speed was at
09-16-2014, 07:13 PM   #2
jpzk's Avatar
I can't read the EXIF data from your image here but I'll start with this:
(maybe some people will come in a be able to get the EXIF from your photo??)
1. the bird is underexposed (metering) ... I would use spot metering for that shot. Did you use matrix metering?
There is a bit of backlight and that will fool the metering quite often ... there are ways to get around that too.
2. the bird is out of focus (user error or lens shake) or you moved the camera while using a slow shutter speed.
3. was this shot at 200 mm ?
4. did you use a tripod?
5. do you have the original image, and not cropped? This would actually help a lot?
6. I assume this was a JPEG shot and not RAW?
Now for the good part: I like this image in spite of no. 1 and 2 above !
I'll return later to see if anyone has "taken over"
Cheers!
09-16-2014, 07:55 PM   #3
I don't know what matrix metering is :/
It was taken at 200mm I didn't want to get to close as I have a minor fear of birds
No tripod
This is the original picture not sure why it looks cropped but I haven't touched it, it is straight from my camera
And yes it was jpeg not raw
I have another picture of him I'll post
This one is the same settings just moved back a touch so I wasnt falling down the hill lol
09-17-2014, 05:36 AM   #4
Cee Cee's Avatar
QuoteOriginally posted by jade Quote
it looks cropped because its not the 2:3 aspect ratio that's normal for aspc cameras, the second shot is normal.
spot metering on the bird will expose the bird better but then the highlights in the background may be a problem, its not an easy task to shoot subject against a bright background like that, there are things you can do in PP but that's a whole different conversation. I think the second shot is better because the tail feathers aren't cut off, and with a bit of a crop and some adjustments in PP.
cheers
09-17-2014, 05:40 AM   #5
normhead's Avatar
Also on the exposure, you can read your histogram, and since the bird is the darkest thing in the image, you need to move the curve to the right, get it near the centre of the histogram window.. the only way to keep your background would be to use HDR, but in this case the background is relatively un-important, I'd just let it get lost in the high lights. Now that little blasted patch on the top of the birds head, that's going to be tricky.
09-17-2014, 12:58 PM   #6
ZombieArmy's Avatar
QuoteOriginally posted by wildman Quote
Other than making the bone-headed mistake of being out of focus that was your first mistake.
At least the OP isn't making redundant sentences.
No need to be so rude with your posts you know, I'm sure you've made the same mistakes when you were new to photography, and probably still do from time to time.
09-17-2014, 01:51 PM   #7
QuoteOriginally posted by ZombieArmy Quote
That was not my intention and if my post was understood this way the fault is mine and I apologize.
I just assumed I was speaking as one adult to another who wanted my honest opinion. Apparently I failed.
09-17-2014, 03:35 PM   #8
If you re read my post it says I'm still learning and in my second picture it says had to move back cause I was falling down a hill.
I know how to shoot raw just choose not to.
I encourage honest feed back how else is one to learn, but there is a right way and a wrong way to give positive feed back.
Thank you for everyone's feed back
camera, critique, photography
Not Work-Safe Opiette - Pt. 2 (straight from the camera, goosebumps and all) alan_smithee_photos Post Your Photos! 5 07-09-2013 12:47 PM
Misc Straight out camera Practice telly0050 Post Your Photos! 3 09-08-2011 08:06 PM
JPEG settings for straight out of camera shots mingdie Pentax DSLR Discussion 20 10-19-2009 08:09 AM
Straight from the camera rmtagg Post Your Photos! 5 05-21-2008 08:08 PM
K10 shots, for the Straight-Out-Of-The-Camera Crowd carpents Post Your Photos! 14 12-03-2006 01:18 AM
All times are GMT -7. The time now is 08:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
