Originally posted by Sprky1285 I bet the 67 created some spectacular wedding shots.
I can't imagine the sound of that shutter thwap during the wedding though! It must have been quite the startling sound to those near and not used to a machine like that.
It is quite disappointing, the sparse nature of labs these days. And most are more simple and refined, the bare minimum to cut costs and expedite the process. Heck, I only know of 3 or 4 labs in the entire state of Florida here. And I am not aware of one that does scans to the quality one might desire in a medium format negative.
I love the Pentax lenses, so the ability to use old and new on the 645z may be the deciding factor in whether to chose, Fuji, Hassy or Pentax (as far as digital MF goes).
Have you noticed that relatively old (for the era of semiannual tech updates) Sony sensor in the 645z showing any age? I am not worried about frame rates or video etc. as that would not be main concern for MF work. Mainly portraiture, landscape and the like.
Thanks for your considered response.
The 6x7 allowed me to charge higher rates, although I still only managed to make enough money to pay for my hobby, which at that time was sufficient. The lab costs were very high in comparison to the one-hour shops for 35mm.
Re your question about the lenses. Most of the legacy (film) lenses for 645 and 6x7 deliver fantastic results. Some of the older lenses from the 70's and prior don't have all the high end coatings and are prone to fringing and chromatic aberration.
If a lens has SMC coatings and ED coatings then the results will be great. Just keep in mind that if a lens has a weak character, it is more likely to be seen in mf than in 35mm FF. Combine with that the all lenses (all manufacturers) have a range of apertures at which the lens renders a sharper image.
As I've mentioned in a previous post, the grain on color film consisted of crystals with sizes ranging from 2 microns to 0.2 microns. The 645z sensor pixel size (pitch) is about 5.3 microns and the newer 100mpx sensor is about 3.7 microns in the same sized sensor. (Google can give you more detail). Thus if a lens was rendering bad results in the film era, it would most likely have been known at that time already.
To get an overview of most medium format lenses and what they can deliver, you may want to scroll through the forum thread "Post your medium format photos". The thread has been active for a number of years already and currently have around 16k posts of mf photos, film and digital and some discussions about lenses.
In mf you also dont need a million lenses, three or four lenses will cover a wide focal range, and even if they don't have the latest hd coatings, the 645z's performance will put your results way ahead of what can be produced with FF. That's my opinion, other are welcome to disagree, just saying. :-)
