Originally posted by cobbu2 Hello All,
I recently acquired a P6x7 body as a second to my existing P67. While testing, everything was great until I attempted to mount a lens. My first try was my 90/2.8 LS; the lens would lay flush against the body mount, but I was unable to rotate the lens to secure it, as if there was some obstruction present. I then tried my 55/4 and had the same result. I also tried pushing in the lens release tab while trying to twist the lens, no dice.
I carefully examined the lens mount on the body and compared it to my P67 (where both lenses fit fine) and could not find any apparent difference between the two.
Am I missing something obvious or is there a real problem here and I need to return it to the seller?
I appreciate your thoughts and suggestions; best regards, Allan
I'm going to guess that the newly acquired camera suffered some damage to the mount. I dropped a Pentax zoom once, in winter, and not a great distance, and it would not mount on the camera after. I could see no visible difference between the damaged lens and a 'good' one, but the repair shop replaced the mount and it mounted again.
