Originally posted by PhilRich I must admit I'm not all that knowledgeable concerning the controls yet. I changed the D-Range settings to OFF. I haven't reversed the setting to confirm that this was the problem or something else.
I have an old Hasselblad CM camera that I should sell - haven't used it for years, so I appreciate the results from the medium camera format. I'm looking forward to rising to the challenge of mastering this camera. Initial hand held shots indicate improvement is needed! I will be using a tripod for landscape.
I find this forum very helpful. There is a wealth of technical and practical information being shared here.
Phil
Hi Phil, welcome.
I too am a new 645z owner. Found a wealth of information here.
I must disagree on one point. with the 55mm DFA, you can get superb handheld shots, even out of a moving car, with one hand! I will post an example later if you like. Of course you need to be at the right shutter speed.
One thing everyone cautioned me about and I found it to be very true is that you MUST watch the highlights and expose for them. Let the shadows fall where they will. You can pull out 4 stops of shadow detail but highlight recovery is rather limited, so if you blow them, they are gone. I always shoot manual but with the Z, I meter the entire scene and expose for the highlights.
Enjoy the camera. I am off to South Africa in two weeks on a wildlife shoot, will take it along with me, see how it does.
Pradeep
