Originally posted by esrandall My experience with a couple of the generic eBay ring flash units, is that they aren't very effective. Even maxed out, neither of them gave off enough light to make a difference. I get better results with the onboard camera flash, and a cheap diffuser. So if you see a $30 ring flash, just know that it's one of those "you get what you pay for" kind of deals. The nice one seem to be expensive for good reason.
Unfortunately they tend to be toys , or you have to find settings that work with the ring flash ... Which can be very unforgiving ( Like too slow a shutter speed )
If you can find a regular flash that sits low to the body , it can help enormously . Pentax AF 200 is a nice flash .
---------- Post added 10-23-14 at 10:24 AM ----------
Budget !
Sigma 50mm F2.8 1:1 Macro lens , sitting on a Takumar 2x Tele converter in a Kx Body .
As for the flash , about $30 worth ..
1/ Ring bracket , $15 or so
2/ Flash unit about $11
3/ Hot shoe adapter + cable about $6
4/ Tottal = $32USD
Tamron 90mm SP Di , Pentax K50
Flash = about $30
C mount about $9
Flash about $12
Hot shoe adapter and cable about $6
Tottal = $27USD
Check out Ebay !
OOOOooooops !!!!!! Swivel bracket ! $4 so add $4 ( I knew I was forgetting something )
