12-17-2014, 09:58 PM   #1
sunshine7913
Guest
Best way to keep and protect films?
Well after I dry films, I saw many water spots and some dusts on film negative. idk how to remove it tho. In fact, I can not remove entire photo flo things on film negative before I dry them all.
12-17-2014, 10:18 PM   #2
blackcloudbrew's Avatar
Yep, those are water marks. You'll need some sort of negative cleaner on them after they dry.
12-18-2014, 06:43 AM   #3
redrockcoulee's Avatar
To prevent them do a final rinse in photo Flo mixed in distilled water and run hot water for a few minutes in the room you are drying them to settle the dust and close the door and not disturb them while they are drying.
12-18-2014, 08:13 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by redrockcoulee Quote
What he said.
Using Photo Flo and mixing it up using distilled/deionized water is the key. If your tap water has a high mineral content it may cause water spots even with Photo Flo. Dust prevention is the part of the equation. If you have running water in the room where the film will be drying making a little steam as above is helpful. It also helps to close the heat vents.
camera, film, pentax help, photography, troubleshooting
Rank your films from worst to best 6BQ5 General Photography 3 11-30-2014 02:58 PM
Best UV filter to protect front element rena Pentax Camera and Field Accessories 30 10-23-2013 09:34 AM
Best way to sell stock photo? Hufseking Photographic Industry and Professionals 6 07-18-2013 03:17 PM
Best way to protect LCD screen? *Rich Pentax K-5 & K-5 II 6 10-15-2012 06:26 PM
Best way to sell some SLR cameras and lenses Colbyt Troubleshooting and Beginner Help 4 04-11-2011 07:58 AM
All times are GMT -7. The time now is 12:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
