Originally posted by KatPal Hello! Thank you for the advice. So I think I am ready for more information
on how to use this lens. I did change the setting inside camera so now this lens works, but few questions to get me started:
1. When manually focusing, i do not trust my eye(I always feel blurry), is there some indicator that tells me I am sharply focused at that point? There was a green light also something red blinked, inside viewfinder that seemed to have blink only at certain time when I was turning the focus ring- is that to indicate I am in focus?
If the K5 is like the K20, there will be a green hexagon in the viewfinder that will light up when the focus is correct. It's between the aperture readout (which will be F-- ) and the light meter scale, above the letters MF for Manual Focus (assuming you've set the camera to Manual Focus with the MF, AF.C, AF.S switch. There's also something called "catch-in-focus." You set the AF switch to either AF.S (single focus attempt) or AF.C (continuous auto focus) EVEN THOUGH you're using a manual focus lens. Then, when you press the shutter button, it will only fire if the image is in focus. Continue to hold the shutter button down while slowly turning the focus ring and you'll eventually hear the shutter fire. I don't personally use this mode much, but some find it useful.
Originally posted by KatPal 2. When changing the aperture on the ring, that is the aperture size that will ultimately be shot, correct?(I keep reading something about aperture being wide open at all times with manual lenses).
Yes, the auto function of the aperture allows you to look through the lens with the aperture fully open for better focusing. Then, when the shutter fires, the aperture also closes to what's set on the ring IF you're in M (manual) mode using stop-down metering with the green button. See my other post above about what you've read.
Originally posted by KatPal 3. Can I change other setting like ISO with this manual lens on? What about shutter speed?
Yes, but there's many ways to set the camera to do this in the menus. I have my K20D set so that the front e dial wheel adjusts the shutter speed and the rear e dial adjusts the aperture setting (though this doesn't work with non-"A" lenses, I leave it like that for simplicity). I then have the ISO changeable by pressing the OK button while simultaneously turning the front e dial. That's the wonderful thing about these...you can customize the buttons to what works for YOU. With these functions set, I can change all the settings I need while looking through the viewfinder...no need to look at the rear screen and change menus, etc.
Originally posted by KatPal Any other advice on how to test and learn the best? I'm thinking of sitting at the table and shooting one object over and over with different apertures to see what happens. can I still shoot something movable like my pets, with this lens? I feel that I will not be able to focus on time?
Confused:-)
I would definitely look at your manual and the menu screens while playing with the controls so you see what's happening on the camera itself as you change things. I'd also go to the library and get a book on basic photography so you can learn the interplay between ISO, Aperture, Shutter speed, Depth of Field, etc. There's so many creative things you can do once you learn the basics of photography that a DSLR will allow, vs. a point and shoot.
