01-29-2015, 11:53 AM   #1
DA* 55mm no infinity
So today I noticed that when I shot a photo of something really far away it was not in focus but something closer was. I put it to manual focus and made sure it was on infinity and took it again but still not in focus. Looking at it in live view throughout the whole range it never makes it to where I can shoot the horizon. I looked at the lens and it seems to movie properly when turning the ring. Is this normal?
01-29-2015, 12:53 PM   #2
Jens Lyn IV's Avatar
This happened to me, and the cause turned out to be a broken lens mount. The bayonet on my K-5 was bent, and this increased the flange focal distance enough that the infinity stop on the DA* 55 was short of infinity.
01-29-2015, 01:16 PM   #3
Na Horuk's Avatar
Just have a question. Are you sure you aren't focusing past infinity? Because modern DA lenses tend to allow focus to go beyond actual infinity (for a couple reasons).
Also, keep in mind that if you shoot wide open, focusing near infinity will not look stunningly sharp even if focused properly. And DoF is shallow even if near infinity.
I'm just mentioning the things that are often the answer in similar threads. Of course it is possible there is something wrong between the mount (acting as a sort of extension tube), so also check the lens and camera mount. If the camera mount is the problem, you would probably encounter similar problems with other lenses
01-29-2015, 01:25 PM   #4
That's not right, obviously. A DA 55 should focus to infinity (and maybe beyond, as Buzz would say). The focus ring will continue to turn once you get to infinity, so no hard stop, like with the FA limiteds, but there should be a point where everything far away is in focus.
01-29-2015, 02:29 PM   #5
Wired's Avatar
I had two copies when I first bought this lens that encountered the same symptom. I exchanged in store until I got one that would focus to infinity. My only problem I've ever had with a Pentax lens.
camera, da* 55mm, focus, infinity, pentax help, photography, troubleshooting
K-30 with 18-55mm kit lens having problems focusing to infinity PHPcat Troubleshooting and Beginner Help 5 07-02-2013 02:37 PM
Da* 55mm 1.4 wont af at infinity Wired Troubleshooting and Beginner Help 4 08-04-2012 01:52 PM
no infinity sign on lens?? canajuneh Pentax SLR Lens Discussion 6 11-02-2011 04:33 AM
Having no infinity focus on manual lens? clockwork247 Troubleshooting and Beginner Help 17 12-23-2010 04:22 PM
no infinity focus? JahJahwarrior Pentax SLR Lens Discussion 2 07-09-2007 04:58 PM
All times are GMT -7. The time now is 08:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
