Originally posted by ramseybuckeye I've not seen many butterflies that let you get close enough for macros, some but not many. I would take a telephoto.
Butterflies inside a butterfly park are quite easy with you getting close, they got used to it!
But the ones you find in the wild!? no way! you better take a 300mm lens and stay around 1.5m or 2m away.
Originally posted by pnoob101 I bought the k3 as a kit with the DA 50mm lens, and i saw a guy doing awesome macro shots with the FA lens
Macro with DA50/1.8, in addition to things people mentioned above, I think there's one more way to get closer with that lens, and it's using a Raynox! it won't take you to a life size magnification, but to get shot of flowers and butterflies you won't need so much magnification!
BTW, I've used mine with a Raynox DCR-150 in the past.
here you can find some of the results.
