03-01-2015, 10:50 AM   #1
Lenses
I have a vintage MV with an assortment of lenses. I have also purchased a K3 and was wondering because they both have the same mounts if the MV lenses would work on my new camera. Thank you in advance for any information you may have.
Rick
03-01-2015, 11:49 AM   #2
FreeSpirit9's Avatar
This might point you in the right direction.
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
03-01-2015, 11:52 AM   #3
jatrax's Avatar
The short answer is, yes. However, they will only work to the limits of the lens, a completely manual lens will remain a completely manual lens.
For more information read this: https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
Without knowing which lenses you have specific information is hard to give. If they are original 'K' series lenses, marked 'SMC' or if they are 'M' series lenses then you will need to change a setting in the menu of the k-3 and use green button stop down metering. For 'A' series lenses just make sure the lens aperture ring is in the 'A' position and you should be good.
03-01-2015, 03:21 PM   #4
Not a Number's Avatar
Related to the above links
The Pentax Camera Lens Compatibility Chart
03-01-2015, 03:34 PM   #5
Scorpio71GR's Avatar
I still use my old K and M mount lens on my K3. Like others have said they are totally manual and you will have to use stop down metering. This is were older lens with an A setting are easier to use. The K mount was introduced back in 1975 I believe, any K mount lens will work directly on your K3. That is one of the greatest advantages of Pentax.
camera, lenses, mv, pentax help, photography, troubleshooting
lenses moeg49 Welcomes and Introductions 7 12-15-2014 10:18 AM
Decided on PK lenses dandeleon Welcomes and Introductions 5 11-06-2014 06:19 PM
K mount lenses ZANNE Troubleshooting and Beginner Help 2 05-24-2014 01:43 AM
All times are GMT -7. The time now is 01:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
