Originally posted by Adam Do not move the aperture ring away from A as this will "cripple" the metering system.
Just a small bit of clarification (hope Adam does not mind)...using the aperture ring on the lens will not harm or "cripple" the metering system on your camera. What it does do is force you to use more limited shooting modes* and limits in-camera metering options.** Unless you are doing macro work using extension tubes or bellows where there are no A-contacts on the mount, there is no good reason to use your lens off the A position.
* M mode or X modes if you want aperture control
** Stop-down in M-mode, None for X, or wide open Av for other all other modes
