Originally posted by Paul the Sunman Are you saying it won't manually focus near infinity? Does the focus ring turn all the way to infinity, but it's still out of focus, or it won't physically turn that far? If you don't have the full range of manual focus, maybe there's some grit in the mechanism stopping it. Do you have another body you can try it on?
I find focus on the DA70 to be very fast and accurate. A dusty front element can interfere with AF, but that doesn't seem to be your problem.
Yes, focus ring turns to infinity, or seems to be on infinity, but it is still out of focus on anything far than 20-30 feet I try to focus. If I switch to closer subject, AF works like a charm. If move away to 20 feet or so to focus, it's just a "stuck" sound in AF without any movement, and no movement in MF at all. None.
I do have K200D, it's a good idea to try although I doubt it will help since DA 50mmf1.8 and other F, FA lenses I have, don't have any problems at all. It must be the lens itself.
And yes, DA70 WAS fast and accurate before it started "hunting" and stopped focusing on infinity. The short period of hunting then stuck...
P.S. Checked on K200D. The same.
---------- Post added 04-18-15 at 10:09 AM ----------
Ok, now it's a big question: what to do?!! Where to fix, or not to fix?
