Thanks for the reply.
I would only take this lens apart as a last resort.
Unfortunately, right now i cannot test my super-tak with this adapter because it has been disassembled comepletely for regreasing and aperture blade cleaning.
As i remember when i focused with my super-tak mounted on this same adapter on the post office across the street the distance read beyond 10 meters (close to the start of infinity),
where focusing with this s-m-c 50mm roughly from the same position on the post office reads very close to 5meters. Everything beyond that, as i have mentioned earlier is out of focus.
As i recall, previous owner used this lens on canon 60d and sony a7s.
What is the cheapest adapter that works 100% on all m42 pentax lenses ?
---------- Post added 05-25-15 at 07:08 AM ----------
Originally posted by Adam Is the way screwed all the way in? If you have an off-brand adapter, it's possible that it isn't machined perfectly and therefore might be giving you trouble. The best thing to do is use the genuine adapter. If your focus ring turns all the way to infinity, it's not likely to be a problem with the lens.
Thanks for the reply, Adam.
The lens is screwed all the way on the adapter. If i would to go any further i only might break something.
Dont know if the adapter is genuine or not, but there is writing on the outer ring which reads "M42 Pentax K/M".
The focus ring is smooth and turns from 0.45meter to infinity with no problem.
