Thank you for the suggestions. The tape did the trick. I have never had a lens element so hard to get out! My first try with the tape was not able to get the element out, but there was a "click" when I went to attach more tape, so that told me the element was moving. I then put some tape on and let it sit for 1/2 an hour to bond a bit better, and then used a loupe as I pulled to make sure it was completely level. I managed to get it out (but the tape was starting to peel up as I went).
Thank you once again.
