Originally posted by mde1970 I've just hit the button and purchased a Auto Takumar lens. I assumed it functioned the same as my super takumar 55mm but just noticed it's listed as having a semi - auto diaphragm. I'm now uncertain if the operation of this will be different to my super takumar lens?? (I'll be using this on mirrorless so any advice much apprechiated)???
Mark
According to this
Early Pentax Takumar Lenses Quote: 1958 Asahi Optical launched their new top model Pentax K - here the rare black version. Basically the same cameras as the Original Pentax but the first Pentax (and one of the first SLRs ever) with Semi-Automatic diaphragm mechanism which can be used with special, marked "Auto-Takumar" lenses.
Lenses can be cocked with a lever without looking at it, in this manner open to full aperture before focussing (if the photograph decides to do so).When the trigger is pushed halfway by the photograph, a lever inside the lens mounting closes the diaphragm to the preselect value through a small pin. The photograph then can do a last depth-of-field check. Fully pushing the trigger actuates both mirror and shutter. After firing, lens remains closed at preselect aperture until it's cocked again. Despite the name Auto- this is what we now call semi-automatic diaphragm
You didn't say which lens you just bought (but presumably not another 55), if it was an 85/1.8, you may be in luck:
Quote: At least two lenses had despite of its name fully automatic diaphragm mechanisms: the Auto-Takumar 55mm f/1.8 in black (1960-1962) and the the 85mm f/1.8 (1960-1962 and black as well).
