Originally posted by Loganberry No idea whether an auto focus lens is a good idea. Do they make life easier?
If you use AF mindlessly, it will help you 70% of the time, and let you down for the remaining 30%.
With each AF lens and each camera body, you really need to learn when you cannot rely on AF.
One issue is when the AF spot area covers more than you think it does,
and the camera decides to choose the background rather than the subject.
Again, many standard zoom lenses have a hard time with viewfinder AF at the wide end,
or you may have a lens like my DA 70 which handles AF well at a distance, but not close up.
Your options are to fiddle with the AF adjustment in the camera settings,
or slow down and use the AF from LIve View, which is usuallly more accurate.
Personally, I find using MF more relaxing - I don't have to worry about second-guessing the AF system.
