Originally posted by niceshot Aperture Control Block failure strikes again.Or in other words your mirror motor. Send it in to be fixed.
If so, this would be a new and unusual set of symptoms.*
Originally posted by sgh-62 I bought the camera new and I have had it for about six months. The battery is fully charged and this problem happens on every shot.
For problems such as you describe, the usual suspect would be a power issue. Low battery, brand-X battery, cheap batteries with the AA adapter...all have been implicated in the past. Another possible cause might be moisture or corrosion in the camera.
I agree with niceshot that warranty service repair is probably your best option.
* At least as far as I am aware. The usual symptoms for that problem are underexposed photos, dim optical viewfinder, and/or (rarely) blurry optical viewfinder due to mirror control failure (aperture block controls both).
