08-31-2016, 12:16 AM   #1
Seeker of Knowledge
aslyfox's Avatar
another newbie question exif solved thanks
ok, when I post a photo to Flickr.com, I get an option to review EXIF data but I'm not sure what exactly I am seeing. I thought I could find the shutter count of the camera but I don't see it. I thought I would see info on what camera I used, found that, and what lens was used, don't recognized that if it is there.
where can I learn about what the EXIF data is showing and what EXIF data, if any, is missing. Here is what my existing EXIF data shows on a shot taken by me while on safari this summer in Tanzania using my used K 5 II
Hide EXIF
JFIFVersion - 1.01
X-Resolution - 96 dpi
Y-Resolution - 96 dpi
Make - PENTAX
Orientation - Horizontal (normal)
Software - K-5 II Ver 1.07
Date and Time (Modified) - 2016:07:04 13:26:44
Artist - R.AllenCorzine
YCbCr Positioning - Centered
Copyright - R.AllenCorzine
ISO Speed - 200
Exif Version - 0230
Date and Time (Original) - 2016:07:04 13:26:44
Date and Time (Digitized) - 2016:07:04 13:26:44
Components Configuration - Y, Cb, Cr, -
Exposure Bias - 0 EV
Metering Mode - Multi-segment
Flashpix Version - 0100
Color Space - sRGB
Sensing Method - One-chip color area
File Source - Digital Camera
Scene Type - Directly photographed
Custom Rendered - Normal
Exposure Mode - Auto
White Balance - Auto
Focal Length (35mm format) - 450 mm
Scene Capture Type - Standard
Contrast - High
Saturation - Normal
Sharpness - Hard
Subject Distance Range - Distant
Print IMVersion - 0300
Compression - JPEG (old-style)
Thumbnail Offset - 12168
Thumbnail Length - 8104
Camera ID - 721576318665xxxxxxxxx
Camera Type - Digital SLR
can anyone help me out?
08-31-2016, 12:42 AM   #2
Closed Account
QuoteOriginally posted by Aslyfox Quote
I'm sure one of the many flickr users will be along to help, but if you want to check your shutter count, you can use this feature on the forums.
Click on articles, and the dropdown includes shutter count.
08-31-2016, 02:02 AM   #3
There are a lot of EXIF utilities available (for free). The one I like is PhotoMe. There are a few more fields in the EXIF area that hold data. On the PhotoMe utility, download it and then just drag an image into it and it displays all the fields.Within the meta data attached to the image, there are also other areas, all of which are generally referred to as EXIF data. Here is the official document describing the EXIF data. Essentially everything you really never cared to know about EXIF...enjoy!!!!!!
08-31-2016, 02:12 AM   #4
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by pjv Quote
thanks just checked out shutter counts on the k 3 and K 5 II
here is a shot of a female cheetah taken in the Serengeti in July
PENTAX K-5 II  Photo
08-31-2016, 03:08 AM   #5
Larrymc's Avatar
The shutter count is usually in Maker Notes and doesn't normally show up in the Exif data displayed in Flickr. ExifToolGUI is an excellent app for most anything relating to Exif information and its free also. You can edit the Exif Information easily.
Hide EXIF
JFIFVersion - 1.01
Make - PENTAX
ISO Speed - 200
Exif Version - 0230
Color Space - sRGB
Contrast - High
Saturation - Normal
Sharpness - Hard
08-31-2016, 04:34 AM   #6
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Larrymc Quote
thanks for the info
here is a photo from the butterfly exhibit at the Topeka Zoological Park here in Topeka KS
I used the K 3 with the pentax 50 - 200 mm zoom + the 1.4 tele converter I am trying to learn how to use
PENTAX K-3  Photo
08-31-2016, 05:19 AM   #7
UncleVanya's Avatar
I think Flickr only displays some fields as mentioned. If the lens is recognized it displays before you reveal EXIF.
08-31-2016, 09:21 AM   #8
Larrymc's Avatar
I've never had Flickr display maker notes data including lens used until I send the data to the Exif file via ExifTool. After downloading the DNG file from the SD card I now copy over the pertinent data to the original Exif file then I use PhotoMove to copy the DNG to folders for editing and store the original DNG off computer.
08-31-2016, 10:08 AM   #9
UncleVanya's Avatar
Interesting. I'm going by other people's displayed data - they may be doing what you are doing. I always wondered why mine did not show.
auto, camera, data, date, exif, exif data, length, lens type, pentax help, photography, shutter count, thumbnail, time, troubleshooting, type
Another newbie question about flash on the K-01 Esposizione Pentax K-01 3 04-27-2013 08:08 AM
Another Newbie (K-30) Lens Question Thread bibi Pentax SLR Lens Discussion 9 04-19-2013 09:50 PM
Another lens question from a newbie endure Troubleshooting and Beginner Help 13 07-26-2012 01:18 PM
another newbie question gokenin Troubleshooting and Beginner Help 3 03-26-2008 07:50 PM
Another K100D Newbie Question shutterpuppy Troubleshooting and Beginner Help 4 03-23-2008 10:10 AM
All times are GMT -7. The time now is 10:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
