Originally posted by OkiDoki Hello everyone!
Hey, welcome!
Originally posted by OkiDoki I bought my first DSLR (K-5) for Christmas. I've been using Helios 44-2 58mm/f2 since then and I really enjoyed it but 58mm is just too zoomed in for me.
Nononoo, you meant to say "it is too telephoto". The word zoom merely means you can change the field of view, lenses with a range of focal lengths (for example, 18-55mm, 70-200mm, and so on). On that Helios, the field of view is constant, you cannot zoom in or out. You can only adjust focus. Telephoto means it is long, it brings far away things closer. Wide angle is the opposite, where it captures a wider angle, essentially moving things further away. Just a tidbit, because knowing the right terminology lets you search for the things you want.
Originally posted by OkiDoki Now I bought the DA 35mm f2.4 AL and I would like to take some pictures outside - like a picture of castle covered in snow, cats outside etc. It's quite cold around here now (around -24°C/-11.2°Fahrenheit) but it's not snowing anymore. Is cold/humidity a big problem for lenses with no weather sealing, should I not take it outside?
The cold itself is generally not a problem. The problem is when you go from cold to hot (or dry to humid), because cold equipment will suck in the moisture and fog up. This can cause fungus inside or even problems with the digital parts inside.
There are some threads and blog posts out there about photographing in winter! The most important thing is that when you come from a cold place to a hot place, you keep your equipment in a bag, better yet put the whole camera bag into a PVC bag, and let it adjust slowly. Please read up more about this if you read in a cold climate. Oh, and this goes for WR equipment, too. Better be safe than sorry. Also, you can only consider it WR if both camera and lens are WR. If one isn't, things can enter and go into the other. Its a system
Also, congrats on nice camera and lenses! They are great bang for buck. You can learn how to use them slowly, and look at the threads on this forum for inspiration on what to do with one or another lens. Helios has a thread
here (and there is also the Soviet lens club thread). The DA 35mm has a thread called Plastic fantastic club - great lens, nice and sharp!
