01-02-2010, 08:34 AM   #1
ducdao's Avatar
What does "preset" mean in lens description?
I recently acquired a lens as follows:
125* CARL ZEISS JENA SONNAR 135/4 PRESET (MINT-)*M42 - eBay (item 230402848298 end time Nov-29-09 09:12:58 PST)
The title says:
"CARL ZEISS JENA SONNAR 135/4 PRESET (MINT-)*M42"
What does the term "PRESET" mean in this case? I originally thought that the lens has only f/4 working but looking at the lens I can see all other apertures as well.
Thoughts?
Thanks,
Duc
01-02-2010, 09:13 AM   #2
Wheatfield's Avatar
There should be two aperture rings. One is used to "preset" the aperture, the other one is used to actually stop the lens down to that aperture.
In use, you would set the aperture ring to the shooting aperture (lets say f/8), which, with old viewfinders, could make for a very dim focusing screen.
So, you would open the lens up with the second ring, focus and then turn it until it stops, which would put you at the preset aperture for shooting.
It was a way of allowing for fast aperture setting without having to count clicks.
01-02-2010, 09:22 AM   #3
ducdao's Avatar
Ah, I see what you mean. For this particular CZJ lens there is only one aperture ring. However, to 'preset' the aperture all I have to do is press the aperture ring towards the mount then turn to the desired aperture then it locks the aperture.
Is this a mark of premium lens or it makes no differnce?
01-02-2010, 10:17 AM   #4
Wheatfield's Avatar
IIRC, the CZJ lenses were made in Soviet occupied Germany. I suspect this lens will be uncoated, but probably mechanically quite solid.
camera, jena, lens, pentax help, photography, sonnar, zeiss
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 33 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Grey" preset in Bridge FHPhotographer Digital Processing, Software, and Printing 8 09-25-2009 11:34 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 06:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
