Closed Thread
Show Printable Version 230 Likes Search this Thread
05-29-2015, 10:09 PM   #511
PiDicus Rex's Avatar
QuoteOriginally posted by bootcoder Quote
Nikon D800
Ahhh,... the one that does the uncompressed clean feed output.
Which is basically proof that the video firmware on the Pentax's is botched, as the hardware used is capable of doing the job properly.
05-31-2015, 04:13 AM   #512
QuoteOriginally posted by PiDicus Rex Quote
nope, it does not proof anything. The chip is just one element. There are many others influencing the capabilities. Like RAM, how that RAM is connected, which io pins connected to what, IO in general...
06-01-2015, 01:08 AM   #513
thibs's Avatar
QuoteOriginally posted by Volker76 Quote
Huh, and sensor guys. Don't forget the sensor.
06-02-2015, 02:29 AM   #514
Danas_Anis's Avatar
QuoteOriginally posted by thibs Quote
Ricoh Pentax use Sony sensors, I do believe majority of them a very capable video sensors, I am more than sure DSLRs like Pentax K30 and up has sensors that are a lot more capable for video than Pentax devs let them be.
06-02-2015, 01:49 PM   #515
thibs's Avatar
QuoteOriginally posted by Danas_Anis Quote
Probably indeed but comparing a D800 to a K-S1 and concluding the culprit is the chipset (or its programing) is far fetched to say the least.
The sensor may not be able to output the same way as D800 sensor. It may be too but IMO this is jumping to conclusion.
06-09-2015, 05:40 PM   #516
Banned
Is this message really pinky on K-S1 ?
06-10-2015, 10:13 PM   #517
thibs's Avatar
Isn't this pink usually used for transparency ?
06-11-2015, 04:36 AM   #518
Banned
Can you, please, provide more information on this ?
Anyway, K-S1 TFT seems to have resolution 720x480.
06-11-2015, 08:12 AM - 1 Like   #519
Debug Menu K-S2
For the K-S2 exactly same procedure as described in this thread for the K-S1 but the model specific filename needs to be:
00077860.551
File name DEVELOP.MOD and contents of both files can be same as for K-S1
06-11-2015, 11:44 AM   #520
thibs's Avatar
Well it is quite old in my poor brain.
As I recall, in they day there was software to edit Icons in Windows (when guys really took time doing such things) like MicroAngelo (Iconedit or something) and I remember the pink color in the background was in fact used for coding transparency.
What I'm almost certain is that, from specs, bitmap do not support transparency. Hence you need to set a color to be treated as transparent.
Usually it was (or is?) 255,0,255 or #FF00FF if you prefer.
06-11-2015, 08:28 PM   #521
Banned
Ok, I changed RGB to BGR. But still pinky at some places.
If it is transparent, then previous screenshot(loading) would not display anything at all
EDIT: pink word used FF 00 FF 00
07-05-2015, 03:51 AM   #522
Banned
Enabling "Serial input" on K-S1 doesn't make any difference. There are ~165 commands in serial shell, but only one command ("?") is possible to use in normal firmware binary.
08-20-2015, 11:44 AM   #523
Any news on a custom firmware?
08-20-2015, 06:44 PM   #524
ZombieArmy's Avatar
Makes me want to learn this stuff and put in the effort myself. Would be nice to enable astrotracing on the k-01 one day.
08-21-2015, 12:28 PM   #525
I have confirmed that changing REGION CODE in debug enable other languages in the menu:
00 - this enable all languages
01 - this enable only European languages
02 - this enable only English, Korean, Chinese
03 - this enable only English, Japanese
Closed Thread
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 & K-5 II 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Film SLRs and Compact Film Cameras 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 12:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
