Originally posted by GibbyTheMole Well, it's possible I wasn't doing it right. I read the way you do it is to gently press it to the sensor and lift it off at an angle. So that's what I did. Should the occasion ever come up that I feel the need to use it again, I'll try the tap tap tap method. Thanks for the tip!
Basically it is a fancy version of a piece of sticky tape, like you'd use to get other goopy tape residue off something. Sticky stuff picking up dry material (and even water spots, etc) and other sticky stuff. If it leaves something behind, simply grab it again with a little less pressure. You don't want to be pressing and leaving on the sensor or glass you're cleaning, just touch/release, touch/release, hit the spots as needed, hit them multiple times it's fine. It isn't a surgical operation (just try to avoid hitting the non-sensor stuff in there, and don't use it on the focusing screen, although it will work well on the mirror).
I think rinsing it off before first use out of the box is a good idea (although I don't think I did that myself). Use the sticky pad when you're finished cleaning to transfer the specks to there, and if you are able, rinse the whole thing off and let it dry in a dust free box or something (so you can leave the case open while it dries). I think the sticky pad has a plastic film on it to protect it that you are supposed to take off and put back but I lost mine so I just rinse it and keep it clean. I just ordered another one cause the Opteka version (same as I have under a different name) was only $8 on Amazon. I never want to be without.
