09-18-2014, 10:39 PM   #1
crossmr's Avatar
Pentax K-M any hope?
My father finally retired and decided to come over to Korea to visit me. Last year I upgraded from my K-m To my K-30 but kept the K-M body. It's been sitting for about a year, but was fine when I had last used it. I dusted it off, and it seemed okay.
However after putting some energizer lithiums in it (the silver ones, kind I always used before) I noticed that with 4 fresh out of the pack batteries, after one picture, it went from green to yellow power.
Also the dial on the back (for zooming in to pictures or setting things like aperture, etc) seems really sketchy. A single click does nothing, several clicks in one direction will get it to move, but sometimes it moves higher or lower.
For example I clicked it over, and it went 1/350 1/500 1/350 (while still moving the wheel in the same direction) bounced back and forth a couple times and sometimes just sat there on 1/350.
I reset the settings on the camera. didn't help.
Anything I can do here, or is it toast? Can it be saved with a servicing? I think I'm not far form the pentax service center here in Korea.
09-19-2014, 12:26 AM   #2
I've had this issue intermittently with my K-x. Pretty basic suggestion: update the firmware if there is an update available?
09-19-2014, 12:39 AM   #3
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by crossmr Quote
Fingers crossed that you might fix this up by manually selecting Li as the battery type in the menus, but the other symptoms suggest something worse, don't they? :-(
09-19-2014, 12:56 AM   #4
crossmr's Avatar
Nope, my camera is 1.11 and latest is 1.11 for the K-M.
So no luck there. I tried an air blower around the dial. there seemed to be some momentary relief.. maybe that part just needs a cleaning. But I'm more worried about the battery showing yellow so fast on brand new batteries.
---------- Post added 09-19-2014 at 04:58 PM ----------
The only two main symptons are sketchy button and battery showing odd power readings. If that fixes the battery and maybe I can get the dial cleaned at the service center (if that's the problem) it might be fine.
09-19-2014, 04:20 AM   #5
patrick9's Avatar
Have you tried cleaning the battery contacts? Over that long of time they could have gotten a thin layer of corrosion or dirt on them.
battery, camera, direction, dslr, k-m, korea, pentax, pentax k-m, photography
Any hope for a Ricoh GR price drop? johnny9fingers Ricoh GR 6 11-28-2013 08:57 PM
Any hope to calibrate monitor? thechumpen Digital Processing, Software, and Printing 42 10-14-2013 09:22 AM
Any hope for an entirely dead 645Nii? tfb Pentax Medium Format 3 06-20-2012 03:21 AM
Any K-m Samples? beethovenspiano Pentax DSLR Discussion 18 11-16-2008 12:45 PM
All times are GMT -7. The time now is 01:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
