Originally posted by biz-engineer On the K-5, there is an option in the "C" menu: "Auto Ev compensation". I did not find any detailed explanation of what this actual does. I tried it, did not see much difference. This option is also available in the K-3.
Are some of you having this option selected? What is the advantage/drawback? Thanks.
I believe it will automatically change your settings to achieve a reasonable exposure when the chosen settings can't. For instance, in TAv mode, you choose shutter and aperture and the camera chooses ISO. Well, if you shoot at f/1.4 and 1 sec shutter in bright daylight, there is no ISO low enough to get a correct exposure. With Auto EV compensation set to ON, it might change your aperture or shutter in order to not overexpose.
