05-26-2016, 04:07 AM   #1
Live View - is there a problem leaving it on a while
I've been using Live View on a KS-2 with manual lenses. But it takes a while to get focus on moving targets. Is there a problem leaving the camera in this mode for several minutes? I read somewhere about sensor overheat.
05-26-2016, 06:07 AM   #2
mcgregni's Avatar
Yes, but there is warning indication I believe. Also battery drain is higher. The best approach is to use LV to get focused then come out of it and use a remote control with mirror up to take the actual shots, especially if you are taking a sequence for different exposures. This assumes the camera is steady and the focus can remain fixed.
Otherwise, just have a spare battery and be aware of the temperature warning .... If it comes on then take a break from LV for a couple of minutes.
05-27-2016, 03:48 AM   #3
k22
QuoteOriginally posted by mcgregni Quote
Thank you.
camera, dslr, photography, view
Broken battery retainer on K30 - is it a problem? Alnjpn Troubleshooting and Beginner Help 26 06-11-2020 04:29 AM
Live view problem with K20d ? shaking a lot! TanGU Pentax DSLR Discussion 13 05-21-2017 12:49 PM
Tip on M-lens metering (is there a problem with that?) GabrielFFontes Pentax SLR Lens Discussion 5 10-18-2011 09:37 AM
Noise (like small motor running) while Live View is activated brosen Pentax DSLR Discussion 4 10-14-2009 10:01 PM
Noise while "live view" is activated Ivo Pentax DSLR Discussion 4 05-03-2008 06:36 AM
All times are GMT -7. The time now is 04:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
