05-28-2016, 11:56 AM   #1
Exposure metering time
I can't see why it is possible to select different light metering times ( 10 second default, 3 seconds, or 30 seconds). Why would someone need to use different exposure metering time? If there is not benefit to use the default 10s setting, then I'd only think that some battery power saving is possible by selection a 3s metering time.
05-28-2016, 12:07 PM   #2
jatrax's Avatar
Determines how long the meter stays on. So if you are trying to save battery use a short time, if you working slow and fiddling with things use a longer time. Otherwise the meter times out before you are ready and you have to wake it back up to take the shot.
05-28-2016, 02:59 PM   #3
Otis Memorial Pentaxian
What he said. Finding the camera "asleep" when go to make a setting change is a pain.
camera, default, dslr, exposure, photography, time
Is metering active all the time? Gimbal Pentax K-1 & K-1 II 7 05-08-2016 08:29 PM
Holy Metering Batman! I Wasn't Using the Exposure Meter jackloganbill Pentax K-30 & K-50 12 03-24-2016 05:23 AM
under exposure in average metering mode slip Pentax K-3 & K-3 II 5 07-10-2015 01:04 PM
exposure metering TakeshiKovacs Pentax DSLR Discussion 4 09-06-2009 10:12 AM
Exposure Metering Timer samiam Pentax DSLR Discussion 11 08-13-2009 10:19 AM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
