Originally posted by awscreo One issue I always had is the focusing system - and I understand that it's sort of a weaker point of the K-1 compared to Canikons, and I'm ok with it since sports is just something I wanted to dip into, not actually that interested in it. However, wanted to ask what settings people use for their sports shots in general.
AF.C has been considered a weakness for Pentax for a while, especially with subjects running directly
towards the lens. So if you are not getting the results you want, you might want to adapt to your gear.
Speaking academically, I would give the following tips:
a) position yourself so that focusing will not be a problem. For example, don't stand in front of the runners, but stand parallel to them. You don't need to take photos of every step the runner makes. Instead, make sure you take only a couple great shots. You can focus on the starting position easily, take a quick burst of the start; then re-focus on something parallel to you and do a burst shot when runners go past you, and then quickly focus on the finishing line. This way you have 3 critical points that you focus on, and you have higher chance of getting it right, than trying to get every step in-focus, and missing 99.9% of them.
Basically, don't try to take a shot that cannot be taken right. Instead, focus on taking fewer photos that you are confident you can nail.
b) pre-focus, use manual focus and hyperfocal to avoid AF problems. May seem silly, but I've seen stunning shots taken with old, manual telephoto lenses. Quickshift lenses have a good advantage here.
c) de-couple shutter button and AF action, so you do not have to refocus every time you take a shot (button customization)
d) if your lens allows, try Catch in focus (CiF, aka Focus trapping). You can use this with many old manual lenses and some modern lenses as well. And you can use CiF with burst mode for higher chance of getting the right shot.
Remember, AF is just a tool. Try to use it well, or use another alternative if it gives you better results. Sometimes we get caught up in the idea that we
have to AF for every photo - but we don't.
