Originally posted by lesmore49 Very nice job. You are an excellent woodworker. Back in the 1980's I rented a Pentax 6 X 7, which had a Pentax accessory rosewood grip on the side of the camera. It was beautiful, effective, ergonomically well designed and an absolute pleasure to gaze upon.
To a certain extent your wooden attachment to the base, triggered my memory of the old 6 X 7 grip.
BTW, if you don't mind me asking, what kind of wood did you use, how did you shape it and what finish did you use ?
Thanks for your comments.
I don't know what kind of wood it was. I made it from wood from a discarded pallet from a work site. It was a light, soft wood (easy to sand and lightweight)
I took a template off the camera base, and transferred it to the block of wood.
Cut out the rough shape by hand saw and holesaw (for the inside curve) and then sanded it to final shape.
I used a section of a biro insert (the plastic tube that holds the ink) - it fits the locating hole on the camera base perfectly.
The screw I got off ebay (about a dollar), and finished with a dark stain and varnish.
One thing to be aware of if, is that there are small raised "nipples" on the camera base that leaves a slight gap between the base and the grip. These will cause the camera base to bend slightly at the centre hole when the screw is done up. I added an adhesive rubber strip to the grip cutting out around these nipples to eliminate this gap, so it is flush with the base.
